I have a 2010 Wake Pro 215. I would like to be able to have "cruise control" at "slow no wake" type of speeds. The Wake Pro already has Ski Mode with target speed, etc...but there is no way to make the target speed, say, 4mph or whatever? I think the current minimum is 12mph.
Anyway, short of modifying the Ski Mode (min speed) Programming, could you use the Learning Key and make the "no wake setting" the actual top speed allowed? What is the minimum setting the software allows you to set for a Learning Key? Is it only able to set max MPH or can you set via max RPM?
OR...is there a better way to accomplish "slow no wake cruse control" on a 2010 Wake Pro 215?
Thanks
Thanks
