Hey, welcome to the forum buddy. Open up the hood, and check if the ski you bought has the original grey fuel lines, as millions of people will tell you, there infamous for breaking apart and rotting inside, causing heck on your engine, and carbs. go get 1/4" fuel line, about 25 feet if i remember correctly, any auto fuel line will do, and replace them all. What it sounds like is the little filters in your dual carb setup, are probably gummed up with black crap ( from these lines and just time ). Open those carbs up ( if your mechanically inclined, which i hope so for your wallets sake ) and clean those little black mesh filters inside with carb cleaner. That would be a good place to start, otherwise it sounds like you got yourself a sick ski! the 787cc is a sick engine, it hauls.
hope that gets you started.
Ive heard also your supposed to mix 40:1, but im sure its all in preference.
:cheers: cam
