Hey guys, I just purchased 2 98 gsx limiteds with the 951 rotax engines from a guy that I used to work with. He needed some quick cash, so I gave 2000 dollars for the skis and a nice aluminum dual trailer. One ski has 33 and the other has 43 hours. He didn't take very good care of them and left them sitting out in the weather so they are kind of faded. When I purchased them he said one of them had a problem and was pumping water into the engine compartment. I got the good one to run the other day and it has 120 psi on each cylinder. I was shocked by the power that the ski has. The other ski was locked up, so my brother and I poured some marvel mystery oil in the cylinders and let it sit a few days and then pulled the head off. Whe cleaned the inside of the cylinders real good and got it freed up. When we checked compression, we had 80 on one and 120 on the other. I can get it to fire with some starter fluid, but it's got bad gas in it. Am I totally wasting my time here. Will the ski run allright with this compression or get any better. Also did a little checking and found out what the problem was with the water getting in the engine compartment. If you are sitting on the ski, down on the bottom left, there is a big rubber hose that comes fom what appears to be the exhaust. That hose fits over a black plastic piece and is attatched by a big hose clamp. Well I can't seem to get that hose to stay on. The guy I bought the skis from says that the black plastic tube that runs up towards the front is split at the seem and that is where the water is coming in. Any one ever heard of this. I need some help and some advice. Thanks T Fred.
