(1996 gtx 787) i just finished putting the engine in the hull.the engine started up fairly easy. the engine sounds ok ,as much as you can tell running on garden hose. i have a rattle or jingling sound in the pump area. if you give it a shot it goes away until the engine is starting to slow back down to idle. after looking through the forums, i seen a couple of people say rattle is normal when out of water when the impeller shaft has no load on it.
i have already changed the oil in pump a couple of weeks ago before building the engine.the impeller shaft is smooth turning and a (good normal) tight in the bearings. the wear ring is in spec when i checked it.
soooo i would like to know what actualy rattles in there if this is normal?
since we had three inches of snow today it probably wont see the water this year to try. if there is something going on i should rip it apart now worst case ..
randy
randy
