f15radar
After years of carefully making sure ropes did not get sucked up, I finally did it
I have a 1995 Sea Doo GTX. The rope is wound up tight and looks like it got pulled into the sleeve that passes into the engine compartment. I have tried to cut it out, but because it seems to go into the sleeve I haven't been too successful.
I just bought this after having a tigershark for years. So I haven't removed the pump before although I know the former owner kept the oil changed and I am sure all the maintenance has been performed.
If I need to remove the pump, is it as easy as taking the 4 bolts off and then another 4 bolts to expose the shaft? Then remove the shaft and slip it all back together?
Or should I just keep trying to cut the rope out?
Thanks for the advice ahead of time.
