jet pump blues
billy62
Does anybody know what other jet pumps off other sea doos will fit my 97 gtx.What size pump does my 97 gtx have,I think its 140mm not sure. Any help would be great.
You could go the "parts" link at the top of the page and do some comparing for yourself. Its a good reference area.
Karl
billy i put a 89 sp pump on my 97 gts. both are 140mm units but the sp was aluminum as opposed to my composite gts. from what i have found most of the 140mm pumps should work on the skis...things to consider reverse venturi and nozzles are different from models w/o reverse.
Why are you looking for a different pump?
Bearing kit?
Billy, you can buy a bearing kit, new wearing ring and go ahead and get a new remanufactured impeller for a little over $100 bucks, do it yourself and save a bundle..........I know that would be a lot cheaper than buying a pump, paying out the wazoo, just to find it blowing out on you too!:cheers:
Your pump housing is part #295500521 and is used in the 1997 models Challenger 1800, Challenger, GSX, GTX, SP, SPX and the XP.
