Ive' been wrenching my whole life and never knew this
Brian J
from boatingmag.com (sorry can't get the image to load but here's the link with it)
http://www.boatingmag.com/blogs/dont-get-screwed
There are three terrible ways to finish a DIY boat repair or accessory installation. One is when the screwdriver slips and scratches the boat. Two, the head of the fastener gets stripped. And three is when the head is wrenched completely off the screw.
As the illustration shows, not every fastener with a cruciform recess cut in its head is a “Phillips.” The Frearson, or Reed and Prince, as it’s also called, is a different head type. Phillips screws have a cross cut in the head with rounded corners and a taper. These features are designed to help the driver bit “cam out”—rise out of the slots of the X—when just the right amount of torque has been applied to tighten them and before enough torque is applied to twist off the head. Over $500,000 was spent in their development during the 1930’s, when they were introduced for assembly line manufacturing of automobiles.
Frearson screws have a perfect cross cut in their heads, one without rounded corners. They are not designed to cam out and so, when used by an attentive and experienced installer, rarely allow the driver to jump and mar the finish. They also allow that same experienced installer more leeway in how much torque to apply for a given application.
It’s important to know the type of screw head you are working with. It’s equally important to use the right size driver with the screw in question. For Frearson, it's simpler, as two drivers fit all sizes. Phillips drivers, on the other hand, come in a wide variety of sizes.
Make your next boat project easier and identify both the type and size driver you need for the fasteners at hand.
Well, I guess I learned something today, 60 years of wrenching and I do not ever remember hearing that.
me too, but i'm going to keep calling both of them Phillips :)
i'm stubborn like that lol
and I have no idea how many KM's in a mile either hahaha
yep, also they had posi drive Philips we all had to buy in the dodge vehicles, now, as of late, had a trans apart couple months ago, now there are torx bits, you all are aware of im sure, how many of you know about torx plus bits ??? cost me 250.00 for a set .... lol
https://www.google.com/search?q=tor...3LKXesATn2YDACw&ved=0CCUQsAQ&biw=1024&bih=637
also have inverted torx, security torx
my buddy works at vw, and they have spline drive ....
here is a current list of all types of screws ...
http://en.wikipedia.org/wiki/List_of_screw_drives
cool .... unless you gotta buy all this ^(^())(_*&)_(^(*_&)&_)
...... 1 little tip if you get a Philips that wont loosen up, before you strip it, dip the (correct size driver ) in some fine valve lapping compound, then loosen it up, ... this makes driver bite into screw ... funny ??
try it and you will say friggen griz .... lol btw, some compound is like 2.00 for your toolbox
I'd like to the find the guy who thought all these up and punch him square in the mush. Also the guy that came up with a 1-7/8" trailer ball as apposed to the 2".
Any King of Queens fans remember this one:
[video=youtube;fp14jarnTP0]http://www.youtube.com/watch?v=fp14jarnTP0[/video]
