This an update of the issue I have with my 95 seadoo gts. It has a rebuilt 580 with just a few hours on it. I rebuilt the carb myself before I put the new engine in. It also has a coffman's performance exhaust on it. On the water in a straight line, it runs really good. It tops out at about 40 mph. I figure that's pretty good for a 580. Engine is really smooth and idles good. Throttle response is decent. However, the moment I dive into a turn at full throttle the power dies off to the point you think it will shut off. The moment the boat levels off, the boat still has a brief "flat spot" and then power returns. I checked the plugs after my last outing and I noticed that the threads looked a little wet with fuel, and the plug tip was black but did not wet with fuel.
With that info, I turned the high speed screw all the way back in and then back it out by about 1 -1 1/4 turn, hoping to lean it out some. The previous setting was more like 2+ turns out, so it probaly was way rich. Still after making those adjustments the problem still exsists. The adjustment seemed to have no affect whatsoever.
I was told by my mechanic that the boat is running very rich and that the source of the problem could be the preformance pipe as it is not warming up as it should. However I checked my pipe on my gtx after the same run and the temps feel to be about the same. On both skis the pipes are almost cool to the touch. I am not convinced that the pipe is the problem.
I suspect the problem is something wrong with the carb itself or could it be an issue with the wear ring. I have checked it and other than some minor abrasion it seems to be okay. What do you think?
