prairieboy
I'm in the process of redoing the top end on my 787 engine. When I pulled the jugs off I could see a little water down inside the crank. Wasn't high enough to cover the bearings but a little damp. I used a turkey baster to get out some of the water but was only really able to get about a shot glass full.
Should I be worried about getting it completely dry in there and how would I do that. I'm not about to split the crankcase cause the engine is still in the boat and I'm quite confident that everything is in good shape.
Also I read that the 787 takes 30ml of SAE30 for the counterbalance. Does that oil end up in the crank or how does the crankcase stay lubed?
Sent from my LG-D852 using Tapatalk
