Waterdog59
I moved this thread from meet and greet to appropriate forum. Hope this is ok.
97 GSX
1) Low power
2) Variable Trim issues
3) Info center gauge inoperative and water has penetrated it.
4) Speedometer inoperative.
5) Issue with steering cable.
98 GTI
1) Fuel gauge inoperative.
2) Hood strut is not holding hood open.
Looking forward to your replies.
Ed in Kennesaw
97 Seadoo GSX
98 Seadoo GTI
Duel Trailer
Reply
Report Edit
Re:the gsx,,,low power, do compression tests to start,,,trim issues,,,join the club,,,sometimes it motirifyou are lucky,,,usually it’s the module,,,hundreds of bucks,,,so just set the nozzle slightly down and be fine…re the info gauge,,,I have managed to take them apart (there are threads out there for that),,,and once the water gets in,,,it’s trapped,,,and eventually corrodes one or more of the tracers,,,if you have an electronic geek friend handy,,,that could save you HUNDREDS,,,re the speedo,,,check that the paddle wheel is there at the unit to the left of the pump,,,could just be the unit,,,re steering cable,,,sometimes water gets past the rubber gromets and the cable seizes,,,if you were able to get some some threads on the hex fitting,,,you can adjust forstraightness under the front hull..
fuel gauge,,,usually the F1 fuse,,,easy repair,,,many threads out here for that,,hood strut,,,join the club,,,try going on line to find an automotive match,,,easy install
have fun
Like Reply
Report
[ATTACH=full]59213[/ATTACH]
Ed in Kennesaw
97 Seadoo GSX
98 Seadoo GTI
Duel Trailer
Reply
Report Edit Delete
[ATTACH=full]59214[/ATTACH]
142 to 144 PSI on each cylinder.
Ed in Kennesaw
97 Seadoo GSX
98 Seadoo GTI
Duel Trailer
97 GSX
1) Low power
98 GTI
Ed in Kennesaw
97 Seadoo GSX
98 Seadoo GTI
Duel Trailer
Reply
Report Edit
POPPS
Gift UpgradeRe:the gsx,,,low power, do compression tests to start,,,trim issues,,,join the club,,,sometimes it motirifyou are lucky,,,usually it’s the module,,,hundreds of bucks,,,so just set the nozzle slightly down and be fine…re the info gauge,,,I have managed to take them apart (there are threads out there for that),,,and once the water gets in,,,it’s trapped,,,and eventually corrodes one or more of the tracers,,,if you have an electronic geek friend handy,,,that could save you HUNDREDS,,,re the speedo,,,check that the paddle wheel is there at the unit to the left of the pump,,,could just be the unit,,,re steering cable,,,sometimes water gets past the rubber gromets and the cable seizes,,,if you were able to get some some threads on the hex fitting,,,you can adjust forstraightness under the front hull..
have fun
Like Reply
Report
Waterdog59
Thanks POPPS, for responding with all the good advice. I will do as you say. Will check compression first on the GSX. I have a new trim motor on order to replace the old rusty motor. I had the trim working for a couple days after I tapped on the motor and replaced the trim switch cover which was missing. It quit working again. Also have a used 97 GSX info gauge on order with all the wiring and connectors that is supposedly tested and checked out good. A little under $300 with shipping, not cheap. I also replaced the steering cable with another used one and it broke in the same place as original within a couple hours of use. Not sure what is causing this as neither cable was seized. I lost one of the rubber grommets after the cable broke. I have extras though as the used cables come complete. I have another used cable on order to replace it with. Will post my troubleshooting and replacement outcomes. Thanks again for your help.Ed in Kennesaw
97 Seadoo GSX
98 Seadoo GTI
Duel Trailer
Reply
Report Edit Delete
Waterdog59
Compression test on GSX.142 to 144 PSI on each cylinder.
Ed in Kennesaw
97 Seadoo GSX
98 Seadoo GTI
Duel Trailer
