Hello,
Please be patient with me on this one
A few weeks back my bilge pump failed, and I took in a lot of water (to the bottom of the battery). I pumped it out and then took out for a run. After about 40 mins in the engine lost power, and shut off. Got towed back to the shop, who said I had about 10 gallons of water in the fuel tank, which they said they pumped out. The shop gave me it back but they told me about a beeping and said it was must be a low fuel alarm. They also put in a new bilge pump.
I got it back to my driveway and narrowed it down to the water separating filter having water in it (beeping went of after i disconnected the sensor wire at the bottom of filter), which I replaced. Before taking the boat out the next time, run on the hose for about 5 mins, and took it out for a run. Everything was fine for about 15 mins, and started getting the continuous beeping and warning light on my fuel gauge again.
I checked the filter and there was water in there again. I replaced the filter, and also siphoned about a gallon from the main tank, and it came out clear. I checked the vent on the side of the boat, and it looks ok (not broken or beat up), and could not see any visible cracks in the hoses.
My questions are, 1.) can water be getting into the fuel from running on the hose? 2.) is it possible that this could be a case of there being residual water in the system from the shop clean out, and just need to flush it through, 3.) is there anywhere else water could be getting in the fuel?
Thank you for bearing with me!
