I need to get a new cover for my 2005 Islandia. What is the best cover for the money that you guys recommend?
I have used waterproofing but when the back part sags (in between the captains chair and the rear port side seat) it makes a pool of water that eventually seeps through. I may make a grommet hole for the back pole so that it stays in place better like the front pole.
The front piece at the stairs seems prone to water penetration by design though.
Thanks. So I’m curious what the snaps are for then if they are there OEM but not for the cover?
there is a shorter storage support post that's only 6-8 inches you use to keep it in a lowered position for storage (see pic from septemberC's post) . I didn't see it listed in the parts list for your 2000 model. It's not listed in the parts list until 2001 and up. IT also only looks to be orderable in the higher year models now as well. Not sure if other models will work with yours or not. The one for my 2007 model looks thinner and longer but I may be wrong. The pin locking mechanism looks to be the same.I understand you have the same Bimini frame I have and wanted to know how you lower it to fit under your cover.
That extra pole he has must have been added to support the frame better in windy conditions.
Ours moves alot when in rougher water with lots of wind due to the taller stance of the islandia bimini, I was contemplating adding an extra pole back there for more support
my 2005 oem cover snaps in place an covers everything except the rear platform and the front deck
