Islandia Cover Tent Pole Support
hjgrimm
Premium Member
Premium Member
We are just starting to enjoy our new to us 2006 Islandia! I have one issue on the cover and need some assistance with a part number. The rear "tent pole" for the cover has a fitting on the floor of the boat to put the pole in, or I guess the appropriate term is should have a fitting for the pole to insert in. This is just in front of the rear seats near an access panel that has screws in it. Is there a part number for this fitting that goes in the hole? There is a larger hole as if a piece of rubber is missing. I have looked at every part diagram I can find and I am unable to locate it. Thank you for the help.
Can you post a pic of it?
On the older isladia's... there is a small drain on the floor, right where the cover pole sits. (just a coincidence on location)
I will take one tonight and post. I'm not sure what happened in winter storage, but the pole would sit nicely there when it was put away, and now falls right down.
I am having problems posting the picture, but I removed the access panel that is right there that gives access to the top of the fuel tank, and there laid a drain, with some damage to the tubing which I will repair. The question now is do you have any pictures of what the assembled drain looks like? I have the drain and a large nut that was on it, but I feel like there should be another piece I do not see. The drain just kind of sits there and flops around which is obviously not right.
Ok I think I finally figured this out. It is seadoo part 204071166 (hopefully because I ordered it.) It appears the plastic color broke and the entire drain assembly fell in.
I don't think my Boat has that cover.
Post a pic when you get a chance. For now... I'm going to look at the parts fiche.
I just looked up the fittig... and mine has that same drain... but I don't have a fuel tank access cover.
This is looking down on the fitting, you can see the access panel there. I hope I am looking at this correctly and got the right part.
Yep..... I can see it now.
The merc powered boats don't have that cover. My fuel fittings are in the back of the tank, since the high pressure pump is part of the engine.
But... I have that same drain fitting. (you can see it below) So you have confirmed my fears. If the pole sits on the fitting... it can break. Also... you should have a little rubber foot on that pole.
