speedluver
Hello all, sorry for this long post, but I think the history here might shed insight into the problem...
I purchased an 01 Islandia in May. The first few times I took it out, it would start immediately and idle at 1K RPM.
After a few weeks, on cold starts, it would fire right away and start but had trouble getting up to 1K RPM for a few minutes. I would turn the wheel for a boost or put it in gear and rev it a little to encourage it and could always get it going.
After a few weeks of that, I started getting a new wrinkle in the process. Occasionally, when turning the ignition for initial startup, it would crank for half a second and then just stop. It made no weird noises, just the starter stopped turning like power being cut to it. I would try immediately again and it would fire up and either run low RPM's or run just fine. Again, in this scenario I could reliably start the boat.
Then, a couple weeks ago I went to cold start the boat and instead of one of these behaviors, the boat just cranked with no fire, for about 5 seconds and then started and ran fine. I didn't think much of it and headed to the beach. When leaving the beach a few hours later, my battery alarm sounded when I turned the blower on (which is usual for me when leaving the beach after running radio and fountain) and I tried to start it. It just cranked and cranked with no firing at all. I would let it crank for 10 seconds or so, then give it a break, and repeat to no avail.
My friend came up on his boat and we raised the engine cover to look at it. The starter pinion looked like it was stuck up on the flywheel in the starting position. It would not come down when the key was released. At this point a storm was starting to roll in, so my buddy towed me back to my dock.
I went out the next day and checked all obvious wires, connectors, and such, and could not get the boat to fire. Just continuous cranking. I hooked up a battery charger with a 50 amp start boost and tried it again in case there was something funky with the battery. Still just cranking and no firing. After I unhooked the battery charger, I tried a few more times and finally it did the previous behavior of cranking for half a second and then stopping. I tried immediately again and it fired right up.
I let it run for 10 minutes or so and went back and looked at the starter and sure enough, the pinion had dropped back where it was supposed to be. I shut the boat off and started it about ten more times with no problem. Then I tried it again and it started the cranking with no firing behavior. Looking at the starter, with the key back to off, the pinon was again up on the flywheel. I turned the key to start and back to off about five times quickly and it started right up again.
So, does it sound like something in the starter is going bad causing the pinon to stay up in the flywheel and causing the engine not to fire even though it sounds like it is cranking just fine? Is the flywheel not being spun fast enough or some safety feature blocking ignition even though it doesn't fire AT ALL when the pinion is sticking? It seems like it should at least try to fire if the starter is spinning. Everyone I have asked about it says it can't be the starter because the flywheel seems to be spinning just fine (granted none of them have much experience without outboard motors or SeaDoo boats), but I can look at the starter when it is not starting and see that pinion up where it shouldn't be and it sure seems like a starter issue to me.
Here are 2 pictures of what the starter looks like when the pinion is stuck up on the flywheel. If I turn the key while it looks like this, it just cranks and will not fire. The next picture is what it looks like when it starts with no problem. Does that spring look right?
Thanks for reading!
Thanks for reading!
