is this a problem or can it be ignored?
gtx1972
i have a 1997 gtx 787, info display has gone and freaked out badly, started off by counting 1111, 2222, 3333 to 0000 on the top display whilst the bottom was a row of rotating stars, 130F temperature readings, low oil warning, fuel gauge showing full (only strange because this has never worked since i have owned the ski, lol), digital rev counter reading 4500-5000 rpm on tick over when analogue clock reading 1200rpm, no readings what so ever for peak mph average mph, hours is just ----, but the ski itself runs fine i am just a little worried incase it is the mpem starting to freak up, so what do you reckon any advice will be gratefully read,oh also i have checked all the earths ran a new one (no difference), checked for water in the plugs and connectors and for corrosion, all seems ok.
paul
You can ignore any problem... but your results may vary as your ski sinks to the bottom in a terrific fireball of amazingnessivity.
as for this problem, if the ski runs fine, my guess is it's the infocenter gauge... you might be able to get a used on on ebay...
