jclack
I've had a the dreaded oil "hydrolock" in one of the engines of my Speedster twice this year, but it doesn't happen all the time. One of the things I've noticed is that both times it happened after I filled the oil tank rather full - above the entry point for the recovery oil hoses from the engines (and is that a bad idea in any case).
Is it possible that oil could leak down through those hoses into the engine or is this just a coincidence? If it is possible, how could I best determine if this is what's happening? I imagine i should pull the recovery hose on the affected engine and see if oil comes out, yes?
Otherwise, it's on to the normal workarounds/fixes.
Thanks,
Jim C
Thanks,
Jim C
