despower
Hello Forum
I've been having problems with my Sporster LE... lots or RPMs but can't get the boat to plane. Just no power. So, I checked this forum, which told me to inspect the impeller gap. I figured that I would also change the jet oil while I was at it.
When I pulled off the reverse gate and nozzle, I pulled of piece of hard black plastic from inside the jet. See attached. My gut told me that it's a piece of the wear ring, but I'd never had to change one out and I never had the impeller off before so I don't know what to look for. I have attached photos of the impeller and it looks to me that the gap is much wider than the spec 1mm so I am guessing that the piece I pulled out if indeed a piece of the ring. The wear ring that's left looks mangled to me, but I don't know what to look for. Can anyone tell me that my assumption of a mangled wear ring is correct?
These things don't seem to be too hard to replace (I have the shop manual), but I'm wondering if I should bring it in the shop to replace anyway. I don't have an impeller removal tool or a shaft holder. Any advice is appreciated.
Des
Des
