Is there a NON-synthetic seadoo oil
speedster4us
I was wondering cause I purchased the boat with a full tank of "seadoo oil" they just never told me that it was synthetic or not. Thanks
yep....theirs mineral or synthetic, and believe, but not sure, they have the same color, just labeled on sticker what it is...
Well, now that you bring the oil up, to the top, I asked the guy I got this Doo from, and he said the the oil he was putting in it was called "Um... something silver..."
Well I'd say that was quicksilver oil Probably TCW-3. Probably the wrong oil.
Please, some of you long time users, recommend me a direction to go.
I figure I may have to drain it, and start over...:redface::ack:
Nate
So timmy is the Mineral oil (Non synthetic 2-stroke oil) cause believ it or not the dealer had NO idea what the mineral oil was. LOL
The oil in my boat is like greenish-blue in color
Mineral Oil is another alternative to Synthetic, though a bit more expensive. about $39 a gallon vs Synthetic $35/Gal. if its blue, it could very well be the outboard engine stuff and could ruin your engine. how much of that blue oil is left? good luck getting it out. you shouldnt have problems though.
Ben
98 Seadoo Speedster
Here is a step by step to the oil pump oil lines (including the rotary valve engine.)
After you drain the oil from the oil lines and refill them, you have to be sure there is no air in the lines when the engine starts up or it will cause the engine to seize up. You need to fill the oil lines back up with oil. To drain the oil from the Rotary Valve Chamber, use a shop vac to suck the oil out of the hose…it’s the one that is 3/8” diameter. I attach the empty lines back to tank and fill the tank. The oil line going to the oil injector pump attaches to a elbow fitting on allows the oil to flow to the pump. I let the oil drain into the oil line to the pump first and put a small cup at the end of the oil line, to catch the oil coming out of the end of full line. Attach the full oil line to the elbow on the oil pump. There is a bleeder screw on the pump. Lay a rag under the bleeder screw. Open the bleeder screw till the pump has oil coming out. Tighten the bleeder screw. Be sure the oil is full in the small 2 lines also. Let the oil seep out the ends of the small lines to fill the lines as best as you can. Connect the 2 small oil lines from the pump to the carburetors. Where the cable is connected is a Disk,(pump lever) that the cable is attached to. Check that the mark on the pump aligns with the mark on the disk. Apply the throttle with the ENGINE OFF and check that the cable is in sync with the oil injector cable. They should move open and close at the same time. To bleed the 2 small lines and get the bubbles out, start the engine, on the water hose. DO NOT APPLY THROTTLE. Let the engine IDLE. Turn the Disk,( pump lever) that the oil injector cable is attached to, to full open so the air bubbles travel to the carburetors and leave no bubbles in the line. Don’t run the seadoo for more than a couple minutes on the hose.
For the Rotary Valve Gear Shaft, attach the hose on the tank and allow the oil to fill the hose and attach it to the case. Recheck all the oil lines and be sure they aren't leaking any oil. If you still have any questions give us a shout.
Karl
