is there a difference between impeller housings
kasne
is there a difference between the impeller housing on a 1997 challenger and a 2000 twin engine challenger, thinking of fabricating a trim system with 2 97 nossles
all of the 140 mm pumps are very close. You can swap nozzles to get a trim system.... BUT... on a boat, your reverse bucket is only good with a regular nozzle. OR... you will have to be careful that the nozzle is in the center, before using reverse.
