Double07
Hello everyone,
I picked up a 2001 Utopia that needed a complete overhaul.
The boat was left in salt water for some time by the previous owner, and it really took a toll on it.
Anyway, I have rebuilt both pump and motor, and I put them back in the boat last night.
When I pulled the motor from the boat, the throttle cable was stiff from rust. Before I put the motor back, I pulled out the shift lever beside the drivers seat, removed the throttle cable and reverse gate cable from the shift lever, and oiled them several times. I moved the cables back and forth to work the oil into the cable. They now move freely, and they appear to be in good shape.
After reassemble, I noticed that the throttle in the engine does not move when shifting into reverse. It moves when I shift the lever to forward, but going into reverse, the throttle cable is not pulled. Is this how it is suppose to work? or did I screw up on my reassemble. If this is the case, does it mean you cant accelerate when in reverse? Not that I plan to race backwards, but wouldnt you need that for maneuvering?
The Utopia only has one lever for F/R and gas (unlike some others that have separate lever for F/R and another for gas)
Thanks
-Chika
Thanks
-Chika
