100guard
forgive me folks., I searched a few times for 'oil', 'low oil' but each time it comes up with 'no results'. That's insane because I can SEE a thread on oil just on the first page lol.
I need help with my 98/99 Speedster SK. I think it's a 98...but I think I went all last yr thinking it was a 99 lol., till after I bought parts for it...that had a yr spec-but which still worked...only to find out from the VIN IIRC that it's a 98...doh!
If anybody recalls., last yr I had the low oil come on, and my impellar shaft or whatever it was done-fuzed with it's outer cylinder. Turned out my "jet pump cone" had a crack and the oil leaked out.
Well., after a few outings this season, yesterday (after 2 hours of boppin' around) I got that red eye of death again and I immediately freaked. Thankfully we weren't...that far away but still a good hours worth of manual labour hehe.
I opened the hatch, engine oil was at medium mark. Even on the inclined position it was a cm above the top of the back end, there's ~2" or more at the front end because it dips backwards right.
So anyway, engines didn't seize., I decided to gamble and just chug along at 5kms/hr back to the launch., 40mins later, we almost arrived there but needed a break, so stopped the engine and achored to swim around for a bit.
Once done, started both up again, another 5mins @ just above fwd idle but then a LOUD blaring FRIGHTFUL solid burst tone came up., I IMMEDIATELY shut the boat off., but the tone/siren kept going for a good 20s? Nothing seized., nothing stalled., just the tone. No smoke., Nadda.
I'm not a mechanic or DIY by any means, I looked at the cones to see if either had cracked (to see if it was the same issue?)...can't see anything from being so far buried inside that cylinder above it. I must remove all that stuff over it to reach the cones right? FWd/Rev deflector and and that nozzle or whatever it's called?
My other concern is that maybe this time the engine oil wasn't feeding properly? I looked and the two tubes on the bottom (where do these feed to?) are full of oil., and they do suck from the absolute lowest spot of the tank so it can't be an issue of the tube curling up towards the more shallow back side of the tank? or could it? I tried removing that top black part, but it's firm in there. How do I remove that? The tube going down from this contraption does what? Maybe this one is curled up? There's a little gap of air as you can see from this housing...could this be at all an issue?
I think it's a waste to fill the oil tank up if that doesn't solve it, so I want to first take that thing off to see inside if there's a feeder tube somewhere above the level-then I'll happily dump my Interceptor in there and be happy the problem is quckly solved!
If it's not the issue, then...I have to take it to a mechanic to look at that cone? I didn't look when the old one died, but it seems like it's open so not sure how you can fill it with fluid and mount it at a right angle without everything pouring out? Or do you have to take out the whole impeller/housing to place vertically and then put the cone on top?
I'm sorry for the laymans terms here...but that's where I'm at.
It's a sunny day, I still have my hatch open, hoping someone can give me a quick couple suggestions to try out before calling it, and finding someone to help.
I turned the power on (batt), and plugged in DESS, but still got the REOD, so I just gave up.
Appreciate the help folks please. I really wanna be able to do this a few more times without too much a hit in the wallet
