Hi all -
This post regards my `04 GTX 4-TEC, which has otherwise been running fine.
I've been cooking batteries this summer. One actually had the negative terminal melt off! Thought it was a defective battery, took it back and then the replacement got almost just as hot, in almost no time.
Upon further investigation, discovered both wires on the starter relay, and the one end at the starter were all somewhat loose. Tightened those and the ski started up much easier. Great! Tighten loose wires and problem solved, right? Wrong. Repeatedly started and killed it about 4 or 5 times there on the driveway, over about a minute's time, to make sure it restarted easily each time. Reached down to just recheck that wire to the starter and it was hotter than a firecracker. The whole starter was hot and the wire was hot enough to melt the end boot.
Took starter apart and nothing visually jumped out as wrong. Brushes looked a little rough, but no burnt smells, etc. Brush wires showed heat discoloration signs, two insulated, two bare.
What's going on? Something's causing an extreme electrical heat buildup.
