ctaylor
Still having symptoms of water in the fuel after tank was drained and filled with fresh fuel in my 2020 GTX 230. Both fuel filters were replaced.
1. A few days after the fuel was drained and replaced jet ski ran great all day long out on the water. HOWEVER, it did idle rough at first and required restarting a couple of times before it got out onto open water and could be opened up full throttle. The ski ran great, top end 65 mph.
2. I replenished the used up fuel with high octane fuel or whatever the most expensive gasoline is these days, about half a tank.
3. About a month after that I started the ski up and it idled smoothly for about half a minute then it began missing badly and would stop running requiring multiple restarts. After about 5 minutes of that bad idling it ran (idled) OK.
4. I repeated this procedure after a couple of times about a month apart each time it had the same result idling smooth for half a minute and then idling rough requiring restarts for about 5 or 10 minutes before it ran idled smooth again.
My theory, and I'd like some comment on it, is that it sets for days and accumulates water from the humidity hear on the coast with its up and down temperatures. The water collects on the bottom of tank which doesn't get picked up by the fuel pump until about half minute later. After 5 to 10 minutes the water in the bottom of the tank is cleared and it idles fine.
Does this sound like water in the fuel? How is water (condensate) getting in there from just sitting outside. (50 feet from the bay). Isn't the fuel system supposed to be sealed up to prevent humid air from condensing into the fuel? BTW, Tthe fuel tank is nearly impossible to get to on this model of SeaDoo.
