BTR
2005 RXT 4-TEC 215 HP.
If you want to replace the internal fuel strainer, make sure you have the correct replacement part (see the pictures below). There are strainers on the market that are sold as being replacements for the OEM internal strainer (which doesn't have a part number because Sea-Doo doesn't acknowledge it's existence), but they don't fit. They look like they'll fit, but they won't.
Notice that the space to the left of the circular portion is wider than the corresponding space on the right.
This is the OEM strainer. It's fits perfectly.
This is an aftermarket strainer. It doesn't fit. Notice the gap to the left of the strainer.
The OEM strainer has its wider portion of fabric on the left side of the circular grommet. However, the aftermarket strainer has its wider portion of fabric on the right side of the grommet. These two parts look almost identical. However, the aftermarket strainer will not fit properly.
Reference:
1. HighFlowFuel.com - Quantum HFP-S34 (includes both the internal and external strainers)
2. RockAuto.com - Airtex FS220 (internal strainer)
Reference:
