YUOnDaGround
1997 Challenger 1800
Twin 787 Rotax
It has been standard operation that my port side engine has a tendency to just cut out when applying the throttle around 3K RPMS. More specifically, I have to ease it up to about 3K then just do a double pump action of the throttle to get it past 3.5k. If I just push it on past the engine will die. I have went through the carbs and even tried a different set of carbs on that engine...does the same thing.
I say that to say this. Today I went out for the first time this season and the same situation with the throttle, no big deal just annoying. Except about 10 min into the ride the exhaust coupler blows out because the water feed line to the second half of the exhaust system that is fed through the pressure regulator on the muffler was pinched. I did not notice this at first, just the extra loud exhaust note and the fact that I did not have to double pump the throttle to get past 3k and it actually rev'd easier. What do you make of this? Something in the pressure regulator? Thanks for your help.
The pictures below just show the actual part on my boat and where they are in the IBP, thought it might help.
Twin 787 Rotax
