I picked up a rebuilt 787 on Craigslist.
Installed it today.
I used the engine mount bracket from my original engine that I took out in the fall.
Here are my questions now that I forget where everything goes:
1. Which oil line goes where? I have a line coming from the bottom of the reservoir that appears to be the feed and another from the top that looks like a vent or return line. My guess is that the feed line attaches just below the carb to lube the rotary plate.
2. I installed the engine and did not use an alignment thing? Am I going to destroy my shaft? I never removed the impeller or shaft when I removed the original engine.
3. Can I use any low ash 2 stroke oil or do I have to use some thing particular?
4. Is there suppose to be a screen that goes in the airbox or a filter or something?
Thanks,
Chris
Installed it today.
Thanks,
Chris
