All,
I purchased an X-Charger upgrade kit with the 42-lb injectors to avoid lean-out and started install today on my 2008 Challenger 230 430 SE. Ran into a bit of an issue :-(. It appears that my boat uses the injectors with the extended nozzle (Model 420874520 injectors) instead of the shorter Bosch 0280155968 injectors.
What are my options? The extended injectors are clearly made to fit deeper into the motor and puting a much shorter injector in seems like asking for trouble. What is the flow rating on the 420874520's? Are there any 42-lb options for the 420874520 injectors?
