Hello everyone. Wish my first post was a better one and Thank you in advance for your assistance.
I am new to the forum and SeaDoo. I just purchased a 2001 Challenger 1800 with the Mercury 240 efi. I purchased this boat a couple weeks ago and my first run on the water was great until I shut it off and then it wouldn't start back up till it cooled for a half hour or so. Once it did fire back up it ran good for another 10 minutes and then started bogging out a bit at full throttle then three quarter and then at half. I took it home and started testing stuff. I hooked it up to the hose and after a few minutes you couldn't see the neighbors house from all the smoke.
Just another tid bit of info the boat sat for two years and a couple weeks before I purchased it the owner had $3200 of work done to completely revamp the fuel system. Based on looking at the receipt it looks like all the pumps, filters and everything was changed out to bring the boat back to running order.
Well I went through and changed the air temp and head temp sensor and adjusted the tps. Took it back out on the water and it smoked a little bit, but not near what it was on the hose. It ran out of the hole great right up to 55 and after kicking around about 20 minutes at half throttle it started to slightly surge at cruising speed. A few minutes later going to full throttle it started bogging down, then at 3/4, then anything above half throttle it bogged. all this happened within 5 minutes back to the dock. When back at the dock I shut it off and it did fire back up, but seemed to be smoking a lot more again. I took it home and did a compression test. all plugs looked ok, and all cylinders tested 108-110.
Any ideas if it might be a vapor thing, tps going bad, or something else. I checked fuel flow on the hose and it seemed ok, but not sure if it things settle and after running a while it clogs.
Also has anyone checked to see if you could retrofit mercury tps indicator 804298t to work on our motors?
Thanks again.
Thanks again.
