I have a 2003 Seadoo gti le rfi my info center is stuck on mph everything else works fuel gauge warning light I have ck the mode button was not working replaced still does not change any help would be appreciated
I haven't worked on that specific problem but I'd check the connections and wire condition. You can probably cut/bypass the button and physically cause the intermittent contact needed to change modes. Good Luck
