2strokeboy
Im not really sure how to explain this bit i will try my best.
So I recently did a fix on me paddle wheel spedo by replacing the components like the magnetic sensor and thermistor and zener. It works at this point and Is installed. So I started up my machine with water connected and the info gauge is reading 22mph so i let it sit for a while thinking it would fix itself. Mind you the speedometer gauge the one separate from the info gauge is reading 0. So after a while I noticed that it is fluctuating between 22 and 0 (video will be posted). But when you spin the wheel the spedo gauge separate from the info gauge starts to move. Also I noticed while the water is off it ready 0 or around 70. I am so confused but im thinking this could do with it vibrating but im just not sure.
