Could someone give me a really good answer to how to look for a bad impeller or wear ring.
My clearence from the middle of my impeller blade to my wear ring fluexuates between .25mm and .40mm ...depending where I measure it...
The only wear on my impeller is on the blades that dont face the wear ring, and there are only small minor pit marks...
Why is there a slight fluxuation when I measure it (clearence) at diffrent parts ie( 9 oclock, 12 oclock, 3 oclock.)
My bearings are super tight.
Should I not worry about it, or replace the wear ring and - or impeller
Could my impeller be slighty bent, and if so is this a big deal since my clearences are all under .40mm ???
Or could my wear ring be warped a little bit ???
Would you spend the money, or do you think It would be better to wait till it REALLY needs replaced.
Im new to this I am not sure.
** also a tip I heard from a very experienced seadoo person...
Changing your pump oil each year is a waste of money. The oil does not go bad, and does not get dirty, its not a motor. Unless water gets in there you are wasting money. Dealers charge $100.00 to do this for nothing. He showed me w an exaple. My ski had 150 hrs on it, never changed. We went to change it, the oil was still clean. he said maybe once every couple years. Delears will tell you it goes bad over the winter.
Thanks,
Greg
Thanks,
Greg
