hello i need to find a new impeller fot my bot sea doo challenger 2000 240 efi mercury v6 2 strok -01. i need the seal ring to bekos i gote stone in the intake, and its broken to ! no to the problem what parts number and how have it in stok, To shipp to sweden. its hot her and i need it now! ;( please :cheers:
The impeller is available (Mercury part number 47-877326T) and a quick check shows the current price is USD 497.91. A much better idea is to have it refurbished. I just did this at a company called Impros here in the United States. Their standard price for refurbing the Mercury impeller is USD 120.00. Here is their contact data:
Impros
610 Amigos Dr., Suite B
Redlands, CA 92373
(909) 793-2900
Their website is what you'd expect,
www.impros.com. They don't discuss big engine impellers much on their website but give them a call and they will tell you everything you need to know.
Regarding the wear ring: Those are also available, either new or refurbished. New ones are Mercury part number 856814A2 and cost USD 489.55. I would try repairing it yourself if all you have is some scratches or gouges. Here in the USA we have a two-part epoxy called "JBWeld" that works very well; many Mercury owners have used it to smooth out their wear rings.
If the wear ring is too badly damaged to repair, then a new one can be ordered using the part numbers mentioned above. Check this forum to see if they have a recommended Mercury vendor. If not, I've had good success ordering from the following website:
http://www.mercruiserparts.com/Show...387&bnbr=200&bdesc=NOZZLE+/+RUDDER+COMPONENTS
...and on this webpage the impeller and wear ring are item numbers 49 and 32, respectively. (Disclaimer: I have no association with the website other than as a repeat customer.)
Again, I recommend you refurb the impeller and epoxy the wear ring. You will save a lot of money.
Report back!
