We have a 2004 RXP 215 supercharged.
I need to replace my impeller and I'm thinking of either standard high altitude (we are at 5,000 feet) or a Solas SRC CD 14/19.
Which would you choose?
Also need to replace the wear ring. There are two replacements, the 267000105 and the "new" 267000372 which some have claimed to have trouble installing. Is there any size differences with these two wear rings or is it just a number change?
I was getting crazy cavitation and when I pulled the pump I saw a piece of plastic fin from the pump support housing against the impeller. So my question is how important are those "fins" and is it worth the trouble to replace the housing. There are a couple of others that appear to be broken off as well.
