Impeller removal tool?
Yes, your impeller is threaded onto the impeller shaft. You have to have an impeller removal tool to get it loose. It should also have a Loctite bond that will have to be broken by adding a bit of heat to the center part of the impeller (only momentary, you don't want to melt anything).
