Linwoodinmaine
I have a jet ski it is a SeaDoo 1997 GTS with the 5018 motor last year when I took it out there was not a lot of thrust to the jet ski so I thought it was the ware ring so i replace that with the new OEM part and realized that the old wear ring stuck out a bit they had also glued the whole unit in with a lot of permatex gasket former when I went to install it again the plastic is on the housing or cracked so ended up getting a whole new lower unit when I installed this one it wouldn't turn over and I believe the prop is hitting the metal housing I've replaced the gasket between them but don't know what to do, it's still hitting.
