Mikum1968
My Utopia only idles at 500-700 rpms while on the hose. Usually dies quickly. If I throttle up a bit (around 1000 rpm), the boat will idle forever.
The Mercury service manual says it should be 1000-1100. Does anyone know if this is the rpm in my driveway on the hose?
Local shop says 1000-1100 in my driveway should result in 500-700 in the water.
The boat has never idled well (like a lot of other jet boaters, I turn the wheel to engage the low speed "thrusters") since I bought it and now I know why.
I can find the idle adjustment screw in the service manual but i also read online that the ECM has something to do with the idle speed? Am I ok to simply warm the boat up in my driveway on the hose and adjust the idle to 1000-1100 using the set screw?
The idle adjustment screw is labelled as "f" in the attached diagram. Seems simple enough to adjust.
Anyone know anything about the "idle timing screw" labelled as "m?"
I did .pdf seach of the manual and could not find a procedure to adjust the idle.
Any help is greatly appreciated.
Michael
Michael
