Identify this XP Limited pic...
David Doo
I just acquired this older XP Limited and would like more info about it; year, hp, size engine, etc...ready to overhaul and clean it up...see pic...thank you
1999 Seadoo XP going by the graphics. The last two digits of the Hull Number (not the registration numbers) are the model year.
It is a 130 HP 951cc engine.
Before spending a dime, pull te spark plugs and see if you can turn the engine over by hand. If it is free test the compression 130 psi is perfect and at 110 or less the engine is done. . DO NOT jump start it.
It does have a hull number! I was looking on the lower right that had a sticker missing, and its a plastic plate mounted just below the rear of the seat.
I have one of those sitting in my cousin's shop. It's at the back of my list presently. Good Luck !!
