Sharkwhit88
Need some help, I had to replace my pump impeller and wear ring. What a nightmare, 45 hours on this machine. Had to cut out the fixing plates to remove the brass inserts spinning within. Finally ordered new fixing plates reinstalled IBR motor and battery and IBR bucket assembly. Ran the IBR in override moves fine,now when testing on the water hose with engine running check engine light is on. IBR light is on. Setting codes U16A4, C2102, P1661. Showing no F,N,R on cluster either battery voltage good, fuse good and system moves in Override only any Ideas? Thanks
