Guest_User
Hi gang, any electrical techs in here? I would like to install a volt meter in that 2" hole that was blanked off and install an hour meter as well to better keep a log on these remans.
Boat - 1998 Challenger 1800 twin 787`s
I have a 12 volt source that doesnt get used which is the cigarette lighter/socket. I`m thinking I can just tap into that for the positive supply for the volt meter with non to minimal drop in Volts. I don`t run anything while underway ie: lights etc.
If that 12v supply is hot at all time`s I might have to install a switch...
I`m also thinking that if I tap into anything else like power for the gauges which come on with the DESS system, I could be asking for trouble, not getting an accurate reading, and possibly fubaring these rare MPEM`s. don`t want that...
The hour meter, I realize it needs a switched power source, but where in this boat?
another option is to utilize 2 hour meters than are inductive off the plug wire...
any info is greatly appreciated, thanks, Andy...
