So after chasing the cavitation all last summer, I decided to really go after it before I get busy this year. Last year I replaced my carbon seal. And replaced both rubber boots by the PTOs. I had no bad leaks coming from that area, but still had horrible cavitation from the port side pump. So I decided to try the wear rings, even though I knew they were only one year old. So today I remove the pump, and examine them closely. This is what I found. One of the veins has a large chunk missing, two of the others have smaller chunks missing. I presume it was from when the previous owner changed the wear rings and used a rod to keep impeller from spinning.
Do you agree this is causing my cavitation??
A local repair place has an excellent condition used pump I can have for $150. Does that sound fair??
