Ended up with 2 thin coats and 2 thick coats of high gloss rust oleum. This is it, dry (well, to the touch). Got a nice gloss to it.
Now is the time when people look at the pics and go "DUDE...You shouldn't have painted THAT part..." so fire away.
The oil lines are all covered so they will be clear. I also covered the entire oil pump assembly, the part with the cam that the accelerator wire hooks up to. I will just grease it up good with some sort of spray lube to keep it dry and freed.
I put an old bolt in each exposed hole, except for the one taped over.
I will have to hit a couple spots on the exhaust with acetone at the top to clean the surface off before I mount the pipes to it. Also where the carbs hook up.
Painted the Rave bases on a wire separately.
The mallet was the only thing I had the correct distance, and the rubber part stuck to the links well. The handle lodged between two links too. I wiggled it around to make sure it wouldn't drop 6" and hit me on the head while I was under it. Still kept my head low, just in case.
I think I will wire-wheel the exhaust pipes and repaint them the same way. I usually rough up the welded in plugs on the inside and dab some high-temp epoxy in there to keep them from rusting out again. They are in good shape, so maybe I wont...
