bigJake
I need someone who understands all the oil techno babble to tell me if the oil I am using is OK.
Seadoo maunal says:
"Use High quality low ASH API TC Injector oil.
Do Not use NMMA TC-W, TC-W2 or TC-W3 outboard motor oils or other ash less type 2 cycle oil. Avoid mixing different brands of API TC oil as resulting chemical reaction will cause severe engine damage. Never mix Mineral or synthetics oil together." whatever that means
I have been using Amsoil HP Injector oil for the past year and just filled 2 skis with $60 worth, because that is what my marina sells. The HP Injector bottle says TC-W3 and API-TC.
I just discovered that my marina also sells Amsoil Interceptor oil which says "API TC, JASO FC".
This Amsoil Chart describes the different oils. http://www.amsoil.com/products/twocycle/2cycle_chart.gif
It appears that I would be better off using the Interceptor oil instead of the HP Injector oil. But is it OK to run the HP Injector oil that I just filled the skis with and switch when that runs out? And can I mix the 2 oils when I switch over?
I tried asking Amsoil Tech support this question, but they did not give me a straight answer. I also posted this question here last year and the only response I got was a link to the Amsoil chart which didn't answer my question, so hopefully someone who really knows can help me out. Thanks!
Seadoo maunal says:
