I changed the jet oil in my 97 xp, and as long as I got the trailer tongue high in the air, I thought I would do the 03 Yamaha right next to the xp. However, nobody makes things the same way and there is a cone but no set screw to fill the cone. Just curious on this one .. does anyone know how to change the jet oil in a Yamaha? The YamahaForum.com is worthless. One day and no replies. That is, there is no Lou on the Yamaha forum.
yeah, but Pale Rider is here! and I miss my 08 GPR!
you have to remove the pump to get access to the grease...
GPR or XLT?
remove steering cable at steering nozzle
slide back the retainer on the quick shift cable and pop off the cable from the ball stud at the steering nozzle trim ring.
disconnect the siphon bilge hose at the side of the venturi/exit nozzle
remove the 4 long bolts that go thru the exit nozzle and pump.
remove the venturi exit nozzle from the pump, sometimes it is sealed on and sometimes not, there are prying ears on the side of the casting if you look, and place your screw driver or small pry bar, one on each side and work off gradually. There are alignment pins , don`t loose these or remove the pins.
pull the pump towards you, sliding the drive shaft out.
hopefully you don`t have massive corrosion causing the drive shaft to get stuck in the mid shaft.
remove the allen head screws that hold the cone on.
you should have grease in the yami pumps. but it is a great idea to convert to oil/grease slurry.
or us a quality 75W85/90 gear oil.
flush the grease out with brakleen or carb cleaner, don`t let it sit in there to long before you turn over and dump out the mess. repeat until the old grease is gone.
with the pump cone side up you want to fill the pump until it is level with the top of the bearing that you see. it will take a little time to get the oil down past the sleeve and into the other bearing, simply rotate the drive shaft back and forth with your hand to speed up the flow...
Look here for pics:
http://islandracingperformance.com/forum/showthread.php?t=781
you will need to register in order to see the pics and read the forum... It is a good forum for yamaha`s...
good luck...
