trickyslip
Hey All,
Last weekend I ran over a ski rope with my Speedster 150. :ack: Luckily it was at the end of a long day of fun, and I was close to the launch ramp. The rope sucked in, and I immediately killed the engine. After clearing the torn rope from the water and starting the boat back up, I was able to get 3-4 MPH out of the boat, any higher RPMs and I would get vibration and what I assume to be cavitation, and no increase in speed. So I just slowly drove to the ramp, and pulled it out of the water. When I got home, I got under the boat and I could clearly see the rope wrapped around a long bar, that I am assuming is the impeller drive shaft (I am not the most mechanically inclined person, but I figured I had to learn this stuff so as not to pay someone 90$ and hour for something I could do). I read the forums for a bit and decided to not try to remove the grate, but instead found a long scissors and cut small bits of the rope away until I could hook some of the loops of the rope and pull it out. After about an hour, I was able to get the rope completely unwrapped, with one end still going into what I assume is the impeller. I gave it a tug and it ripped off.. (Seems like it was already pretty munched up as it was). So my question is, can I put the boat back into the water, or is there more insides I need to open up and inspect? I was going to connect the hose to the back and start the engine in the drive way and see if I could get the RPMs up, without vibration.. Is that a good plan?
