hyrdo turf install
boggs
Hey how long do you leave presure on the hydro turf when you are doing an install. Im hopimg to get it all in tomarrow.
I recently installed mine on a 2007 speedster. Cleaned the area with Windex (alcohol could be better).
For pressure, I spent a few minutes with each section walking or pushing with my heal. The 3m backing is pretty impressive. When you're done, try gently lifting the edges. If any areas come up, you missed applying pressure.
Other guys have posted that it worked good to use a kitchen type rolling pin. I just put some heavy stuff on it like books and boxes i had laying around the garage. I just left it sit for a few hours then took it all off. 3 years late its in good shape still . And use rubbing alcohol to clean each area right before you stick the turf down.
