Hull pee hole?
mnm99
I have a new to me 2008 RXT 215. Question about the 2 outlet fittings front starboard side. . I have no water coming out of either. Upon inspection I noticed one is a vent hole for the fuel tank and the other is a 1/4 line that is just laying inside the hull?? Both are connected to the fittings on the front right side of the hull. What is the 1/4 hose one that’s not connected to anything? No water spraying in the hull either. Thanks
I am not aware of one on the models with the 4-tec engines including yours.
They have a rigid water pump impeller, not a flexible rubber as used in many boats which can harden over time.
Edited to clarify- the impeller is for the closed loop system. Exhaust manifold and supercharger if equipped are open loop cooled using pressure created by the jet pump,
Great thanks. So there is no water hole that shows it’s cooling on this ski?
Closed loop cooling. Water is not used to cool your ski's engine (but is for the exhaust).
If you don't know if/when the coolant was changed, it's time.
