AirSniper
2003 Utopia - I had to replace my bilge pump. The design has changed and I had to replace the base as well. The old base is riveted in, so I drilled the head and removed them easily enough.
The new one is installed with metal screws (and pilot holes). Now I question myself since this area is always in water. My concern is if the core of the fiberglass is made with balsa wood, the wet wood will rot. I've seen this on sailboats.
Would anyone know the makeup of the hull and if I need to be concerned?
