WaterEnthusiast
Hi there,
I recently acquired a 2008 Wake 215 Sea-Doo (GTX) and after changing just about all the rubber grommets and various sleeves that were cracked, as well as the jet pump housing and the bearing inside, I am finally ready to start the season.
However, after reassembling the whole thing, I was told that, for 2008 Sea-Doo, I must keep a careful eye on the Seal Tubes that are used in the O.P.A.S. (off-power assisted steering).
You can see part #10 in the following diagram: 2008 Sea-Doo WAKE 215 Off Power Assisted Steering | Fox Powersports Sea-Doo Partshouse
This tube links the O.P.A.S. side vane to the venturi which is linked to the handlebar. It goes through the hull, from one side to the center. If it cracks, water could enter in the hull and eventually sink the Sea-Doo.
I have the shop manual for my Sea-Doo, and it seems that removing those two seal tubes requires some work, including sealing silicone inside and outside each side of the hull to seal the screw holes. Given that I JUST reassembled everything with grease and sealant and Loctite this morning, I'd like to have an idea of their current state before taking on this task.
So, my question is: Is there a way to TEST/INSPECT those 2 seals for their integrity and know if they are leaking or not? Is it indeed frequent that they rupture/crack?
Thanks
Thanks
