S seadooer2022 Member Dec 26, 2024 #1 95 GTX, need to uninstall the oil pump for now so I can drill out the stuck carb bolt, but seems the pump is attached to the gear/shaft inside and won't come out, any tricks to this? Last edited: Dec 26, 2024
mikidymac Moderator Staff member Moderator Friday at 2:05 PM #2 You have to remove the outer cover with the Allan bolts then the nylon gear from the pump.
