How to remove bow backrest bolt
freddy2
Ok here what I have 95 seadoo speedster
well from what I have read there no bolt and 10 mm nut on the bow backrest
well this one does have one pulled and pulled till it pulled off the back rest
now there is now way to get at the nut to remove it ??
any one had this one before as what I am thinking of doing is drill a 3.5 inch hole under the bow cushion so I can reach it
is this the thing to do
Manfred
Hu?
The bow seats on the 14.5' boats didn't have nuts or bolts. There isn't any way to get to them.
If it's a different seat... post a pic.
Here a few pictures as you can see the bolt still in there
was thinking to dill a 3.5 hole were the tape is sitting there nothing under there as I look it over IMG_0036.JPGIMG_0037.JPGIMG_0038.JPGIMG_0039.JPG
I added a couple of pictures where the bolt is the pic with the tape is where I was going to drill a 3.5 inch hole
do you think that would be ok
Well.... Unless there was an oddball out there... that's not factory. The bottom should have been stuck on with body spikes... and the back would have had 2 body spikes, and two top pins that lift out. But, in your pics... it looks like the original holes were damaged, and cut open.
Anyway... yes... you can cut a hole in the bottom fiberglass, to reach up, and install a bolt.
yes it must be factory that way on this one as it the same bolt as the ones on the back seat
must have been done when they put the top on the boat
anyway cut a 4 inch hole and remove the bolt and nut no problem
thanks for your help will post a pic of the hole later
here what I did cut drilled a 4 inch hole removed bolt and nut had to been factory done that way reinstalled with new backrest cover
